Unfortunately, I seem to be inadequate in designing search strings and have not found any previous posts that answers the following question.
I have a 2009 Hyundai Sonata with a sunroof. The sunroof has begun to make a noise due to body flex... the noise is from the rubber seal rubbing against the painted edge of the roof. I opened the sunroof and gave the painted edges a quick waxing with A16 cleaner wax and wiped the seal clean with some ONR in detailer strength. The roof was once again silent but it only lasted a couple of weeks and now the noise has returned. This noise has been mentioned on the Hyundai forum I hang out on so it is fairly common. The noise is faint.... closing the headliner panel blocks most of this noise out but I have a keen ear for such things and the faint noise just grates on my nerves.....
I have found in my travels suggestions for silicone greases (don't like that idea... dust and grit is common in the air here and that would just turn into an abrasive paste), Zymol Seal (a collection of organic oils that again would probably attract grit and considering all seals are now made from pure synthetic materials, why would I use vegetable oils to condition it?!?!) and lastly I see a recommendation for 303 protectant (which seems to make the most sense but I don't have any to try).
I do have M40 but I'm not sure this is the right product for this particular job. I don't want the seal to stick at all but rather slide effortlessly against the painted edges without attracting grit/dust. Any suggestions?
Almost forgot, I've also considered Door-Ease (a stick lubricant for door seals) but again.... this is a sliding rubber seal...... I need it to slide and not attract dust/dirt and yet stand up to car washes.
Regards
Christian
Regards
Christian
