Hi guys. Would you recommend using Diamond cut as a surface prep prior to using DACP?
I am thinking that the DACP should be should be able to clear up most swirls and scratches.
However, there is a recommendation that I use Diamond cut as a surface prep each time before I use DACP.
Will using Diamond cut all the time remove all my paint?
