recommendations to cut polish sealant and wax
  • recommendations to cut polish sealant and wax
    I'm new to forums!
    I have used meguiars only!
    I'd like to use just 4 products as a base.
    I get a little confused when looking through all the pro line products can anyone recommend 4 complementry products
    Re: recommendations to cut polish sealant and wax
    Originally posted by jay jay View Post
    I'm new to forums!
    What machine will you be using? Or any machine at all?
    For DA/Rotary Use, the new hotness are
    M105 - Compounding/Cutting
    M205 - Polishing
    M21 2.0 Synthetic Sealant - Sealant
    M26 Yellow Wax - Carnauba Wax
    For Hand (Consumer line)
    Ultimate Compound - Compounding/Cutting
    Swirl X - Polishing
    NXT 2.0 - Sealant
    Gold Class Liquid Wax - Wax
    Also, you could get 12oz samples at autodetailingsolutions.com
    So I recommend you try them out first.
    2006 San Remo Red WRX TR
    2005 Ford Ranger XLT
    Detailers clean places nobody see. Detailer see's things nobody else see. But if you ask a Detailer to see how a dress looks on a woman, they are blind.
      I have a porter cable
      I have used the mirror glaze line.
      Currently using 84 3,9,21,and 26
      But I dont know if that the best way to go?
        That is a very good list of product you are currently using there. You wouldn't even know the difference by using some of the newer products. Work with what you have, and switch to the newer products after you finished the old ones.
          Thanks for the info!
          I'll check it out,by getting some samples.
            One other question.
            When I use my pc polisher, i put a ccs pad on it with a woolly and then a microfiber bonnet, I use higher speed setting and the pad seems to get too hot.
              What? You are polishing with a microfiber bonnet, which is wrapped around a wool bonnet, which is wrapped around a CCS Pad?
