Cleaning the Cobwebs
  • Cleaning the Cobwebs
    Hi,
    So after getting all my supplies this week for washing (Grit Guards, ect) I thought it was time to do some work on those ol' swirl marks. I washed then clayed for the first time on this car, which wasn't dirty at all. I could feel the slight difference, and the clay barely showed any dirt on most of the car.
    On to those swirls... I started with some SwirlX on a small area on the hood where there's some swirls and one larger scratch. I put 3 coats on which didn't show much difference. I then tried some ScratchX 2.0 on the same area. 3 coats of that with only a very small difference showing.
    How many coats should I try?
    The thing that bothers me is the car is only 6 months old, and I didn't think the marks would be this bad.
    Here's some pictures:
    Of the larger scratch (before/after):
    So should I go for some most coats, or go out and get some Ultimate Compound? It sorta grinds my gears to be using UC since the car is still pretty much new. But oh well I guess...
    Thanks,
    Matt
    Re: Cleaning the Cobwebs
    Hi Matt,
    Welcome to MOL!
    As for the situation, you used a word that stuck out to me so I want to make sure that you were using the proper advice before speaking to the need of Ultimate Compound. You said you put "coats" on, so by that do you mean you actually were spreading the product without pushing it into the paint and then wiping it away? Then repeating that process as if it were a wax?
    If not, can you describe how you used the products and how much force (light, medium, fairly hard) you did use?
    This will help greatly!
    Mark
      Great set of eyes Mark... I agree if you are only putting on coats and not working it in that could be one of your problems. We are here to help so please be specific.
      2007 Dodge Nitro SLT
        I think Mark hit the nail on the head.
        You don't put "Coats" of polish, you work it in.
        And for the "swirls on a new car" thing, it's normal. Infact, I think there's some strange conspiracy from dealerships to put swirls on cars to keep Car Crazy detailers like us in business.
        2006 San Remo Red WRX TR
        2005 Ford Ranger XLT
        Detailers clean places nobody see. Detailer see's things nobody else see. But if you ask a Detailer to see how a dress looks on a woman, they are blind.
          Hi Matt,
          Welcome to MOL!
          Mark
          Hi Mark,
          I've read a bunch of different threads here plus some videos, so I'm not sure what I got from where. But what I did was: Spread the product out evenly with a foam applicator, then started working it in with medium pressure until the haze started to clear up. (With SwirlX, I started getting little flakes of dried residue after about 15 seconds of rubbing it in.) After the first coat, I wiped it the small amount of residue leftover. I didn't see much difference, so I went for the 2nd and 3rd coat. Only difference between the 2nd and 3rd, I added more product on the applicator just as the white haze started to clear, instead of wiping inbetween.
          Is this correct? Anything I should add or change?
            Well aside from pressure another thing to look at is the size of your working space. Are you working on a 12x12 area (roughly), or an area much larger? If you work smaller areas it tends to be much, much for effective.
            As for pressure, you should really be pushing quite hard if the medium pressure isn't seeming to be helping.
            I took a closer look at your pictures and some of those scratches look really deep. Can you feel any of them with your fingernail?
              Originally posted by MtCamry09 View Post
              Hi Mark,
              Actually that seems correct. It seems like swirl-x just isn't cutting it because it's a light polish and not meant to take out deeper scratches. The cobwebbs I assume are deeper than normal swirls.
              I'd bump it up to UC followed by swirl-x and see how that works.
                You could try to shrink your work area. If that doesn't work I would just move on to a more aggressive product.
                Remember that you are using a very light cutting product
                  I kept my working area pretty small (12x12 seems about right). I tried to keep the pressure even on the pad so it wasn't applied just where my fingers were. Although I pushed pretty hard on the following coats (possibly some anger fueled 'passion').
                  Should I just skip the SwirlX and put a few more ScratchX 2.0 attempts on? I'd like to see what I could get done today without any trips to the store.
                  Thanks for the replies!
                  -Matt
                    You have seen this clip also?
                    How to correctly apply ScratchX to remove swirls and scratches
                      Definitely step it up to ScratchX 2.0 if the SwirlX doesn't seem to be changing anything.
                        Ah, yes that's the video I saw before.
                        Well I finished one half the hood with ScratchX 2.0, and it looks somewhat better. There's scratches still visible looking from the right angle though. I'll finish up the other half tomorrow and put some NXT 2.0 wax on. Unfortunately I don't have time to make it perfect right now; although I would like to.
                        I'll pick up some UC for the next polishing session, which will probably be before winter comes around.
                        I'm not sure if there's an answer to this, but: How much paint does ScratchX remove? I'm thinking it could vary greatly on how much product you use and pressure you apply. Is there a broad guesstimate on how much is removed (mils?) generally?
                        One quick final question:
                        What's the best way to protect the black plastic molding on the doors from fading? I'm gussing what I'm looking for some type of UV protection? Any good products to protect it without adding a gloss? I've heard Back-to-Black is pretty popular.
                        Okay, two quick final questions (): How about maintaining the chrome molding, or should washing be enough?
                        Thanks!
                        -Matt
                          I've had some problems with ScratchX 2.0 and have tried it several times using proper technique. I personally think stepping it up to UC will yield you better results.
                            Well I picked up some UC today, and actually had some time to use it! I put 2 applications of UC on followed by one ScratchX 2.0. It's not 100% better, but the best I could do without a DA (my arm was about to fall off). The scratches are still visable from the right angle, but atleast they don't catch your eye like they used to.
                            I followed it up with a coat of NXT 2.0 wax. I tried to get good coverage, but in doing so I may have put too much on. After an hour, the swipe test still smeared. I might QD tomorrow and put another quick coat on.
                            Thanks for all the help everyone, I really appreciate it
                            -Matt
