Clay Question
  • Clay Question
    how many times can you use a single clay bar? And when you use one should I fold the Clay over so the dirty part is in the middle and then work with the clean part the next time?
    Thank you,
    Jason.
    http://www.firstcoastautodetailing.com
    Re: Clay Question
    Most people say three or four times is the life of a 50g clay bar (which I think is what comes in the smooth surface clay kit) depending on how dirty the cars you are claying are. Yes, knead it constantly and if you drop it throw it away. If you see any big pieces of dirt remove them if you can. You can never use too much quick detailer, but too little can cause you to mar the paint if the clay is rubbed on a dry surface. I am going to start cutting my clay up into three pieces after being recommended that by someone on this forum.
      Re: Clay Question
      Thanks for the quick response... I will do as you said.
      Thanks again,
      Jason.
        Re: Clay Question
        Untill it stops working.
          Re: Clay Question
          1/3 piece of clay and bottle of detailer as above.
            Re: Clay Question
            So I should take the single piece of Clay and cut it into thirds and use 1 of the 3 pieces correct? If so what size car could that piece do?
              Re: Clay Question
              Very good points to follow. Rule of thumb: if you knead the clay bar and you cannot fold it to a clean area of the bar, then you need to throw it away.
                Re: Clay Question
                I tend to cut the 2 bars in half to use.
                Once they seem a bit dirty from the paint and glass, you can still use them on wheels and exhaust tips, etc
                  Re: Clay Question
                  Glass?? you can use the Clay Bar on Glass?
                    Re: Clay Question
                    You can use clay on anything hard and smooth.
                    As mentioned, just dont use it on your wheels, then bring back up onto the paint.
                      Re: Clay Question
                      Cool.
                      Can I go from glass to paint? or when you use it on glass it is used for glass only from that point forward?
                      Thanks man.
                      Jason.
                        Re: Clay Question
                        The glass is pretty much going to have whatever the paint has on it, so you can go back and forth. Just remember you'll want a glass cleaner after.
                        Down in the wheels, you are going to have metal bits like break dust.
                          Re: Clay Question
                          Cool.
                          Thanks man.
                          Jason.
                          You can go from paint to glass or glass to paint whenever you clay. I always clay the glass whenever I clay the paint, using the same clay bar. You'd be surprised how much **** clings to glass as much as it does to paint.
                            Re: Clay Question
                            Thanks for the into guys....
                            Jason.
                              Re: Clay Question
                              So as a pro detailer your saying to use a piece of clay once or twice?
                              That's just not true.
                              You can use it over and over again, until it stops working. I do many, many, many cars with one bar.
                              Clay can last a long time.
                              Don't waste it, use it.
