Light Scratches what to use??
  • Light Scratches what to use??
    Have an 01 WS6(TransAm) not a daily driver, paint in very good condition. Washed it and tried the clay bar was very happy with the results. I have a lot of light scratches throught the car and not sure what product to use to remove them Also not into using a buffer just like doing it by hand. Keeps me closer to my car. Need suggestions on what to use or where to start. Not a pro with detailing but not a newbie either.
    Re: Light Scratches what to use??
    You will want to look at SwirlX and Ultimate Compound.
    Try a test spot/area with the SwirlX, and see if it works. If not, then try the Ultimate Compound.
      Welcome abord!
      A good place to start is swirl X using a foam pad. Do this section by section as this will take some time to complete an entire car.
      Take a look at this link....
      http://meguiarsonline.com/forums/forumdisplay.php?f=138
      Post a photo of your progress. Happy detailing.
        Hello and welcome to mol.
        I would go with the Swirlx or the ultimate compound. Try swirlx on a small test spot. See if you get the results your after. If not step up to the uc. Good luck.
