using UQW
  • using UQW
    What is Meguiar's recommended way to apply UQW?. In the How to Use the PC for Showcar Results, Mike Phillips sprayed NXT Spray Wax on an applicator pad and wiped it on the car like you would a regular wax. Is this the way to apply UQW? Hopefully one of the Mequiar's guys will answer as to how Meguiar's recommends applying.
    Dave
    You repair things with tools. You fix things with a hammer.
    Re: using UQW
    I give a spray of UQW to a microfiber towel, then spray the surface of the car I'm waxing. I spread it with the wet side of the towel then just flip to the other dry side of the towel and wipe it off. You don't have to wait of UQW to haze, that is what makes it so quick.
    Remove swirls my friends.
      Re: using UQW
      I prime the towel, and also spray the surface. I figure that lets it sort of "pre-soak" the surface.
        Re: using UQW
        They times I have used it I use it like a quick detailer, mist on wipe off. Just saw this write up it may help Secret to Applying UQW
          Re: using UQW
          Thanks John, that link gave me the answer I was looking for.
          Dave
