Some questions I have
    Re: Some questions I have
    Originally posted by 240SX View Post
    So does M40 do the same thing that 303 Aerospace Protectant does, because I was planning on using that.
    M40 is in the same category of products as 303
    M40 is a cleaner/conditioner, it has enough cleaners to tackle some light to moderate neglect/dirt build-up.
    I'm not sure the 303 offers this and if it does how much cleaning ability it offers. If you pre-clean with M39 or something like it then you don't need a cleaner/conditioner like M40 if you prefer to use a straight protectant.
    Make sense?
      Make sense?
      Yes thanks alot.
      I will be trying the Water & Woolite mixture, then #40
      I will let you guys know how it turns out this weekend.
      Can any of you recommend a good plastic polish as my plastic looks quite scratched, even with all that dirt on top.
        Try PlastX PlastX Clear Plastic Cleaner & Polish
        It might work. It says it's for clear plastic but might work on your dash
        DO A TEST SPOT and see if it works.
        I looks like the area around your vent is cracked, if that's the case you can't polish cracks away.
          No, theres no crack there. I might try some PlastX. Any other recommendations guys?
          • #20
            well compounds will work
            here's a guide on aggressiveness
            Just do a test spot first
            These products aren't made for your application but still might work.
            So just be careful and you'll be fine
            Aggressiveness Order for New Consumer Products - This will surprise you!
            • #21
              Try Spray Nine multipurpose cleaner. It's on sale at Canadian Tire for half price. I just used it today and it easily removed the grime build up from the vinyl and plastic near the doors.
