Some questions I have
  • Some questions I have
    Hey all,
    I've been doing alot of reading here and on other forums about detailing. I think I'm ready to tackle my first project. I have an 1989 Nissan 240SX that hasn't been driven for like 8 years. The interior is pretty dirty, as you can imagine, and theres lots of nooks and crannies I have to get into. And a crapload of vinyl and plastic. Unfortunately, i'm in Canada so we don't have APC here.
    My first question: Is Meg's QID good enough to clean a really dirty car, or is it, as the name implies, for quick detailing. If not, what can I use.
    My second question: If Meg's QID can be used to clean my dirty interior, should I buy Meg's #40 (The Vinyl/Rubber cleaner) or is this redundant.
    Last question: Does Meg's QID do the same thing as Simple Green, or does one clean better than the other?
    Thanks for any help
    Re: Some questions I have
    I would use something stronger, APC or the like
    I like 40, but not on a really dirty car
    And I don't like Simple Green
    Your probably going to need something stronger than QID, SG just might work
    Start with QID then SG and if that doesn't work go with and APC
      Again, I'm in Canada so we don't have APC here. And i don't want to have to pay $35 to have it shipped here
      You say you don't like Simple Green, what about Turtle Wax ICE total interior care, any better than Simple Green? If not, what do you recommend as a substitute for APC that I can use for my interior.
      I just don't want to end up buying 20 different products in order to use them once.
      Last edited by Markus Kleis; May 24, 2009, 07:44 PM. Reason: No clickable links before 30 posts
        Try this website: Meguiar's (Canada). I'd say try to get APC+, because I'm told it's more versatile than APC and doesn't foam up as much. If you can't get what you need off Meguiar's Canada, you might just order from Auto Detailing Solutions. Make sure you have a decent size order though to make shipping worth your while.
          I ment use some kind of all purpose cleaner, not necessarily Meg's
          I use Purple power diluted like 10:1
          You just need a "cleaner/degreaser"
            if your car interior is as dirty as you say,I would remove the 2 front seats and wash with an aqua vac(not leather obviously).If you get good weather they can be dry in the sun in no time as the aqua vac should lift out the water.
            While the seats are out,you can get good access to all the areas that you'll want to clean.Your job will be easier.
            Meguiar's interior detailers and dash cleaners are fine,but you'll want to remove some of the soiled dirt from your plastic surfaces.for this i use a bucket with a small amount of warm water,sponge and meguiar's car shampoo.Make a lot of foam in the bucket but squeeze the sponge before applying.Don't soak your interior and get things wet.I have a lot of crevices on my plastic dash(skin effect) and the dirt is really tough to come out.I find a little nail brush does the trick here,but not one with extremely stiff bristles.Be carefull when cleaning near or around the lens/cover on your instrument panel.they scratch very easily.
            Cheers!
              I plan on renting a Rug Doctor when I take out the seats, so that takes care of the upholstery and carpet.
              Can you give me some more info about this Meg's shampoo. I can't find anything like that online here in Canada. Do you mean like regular car wash shampoo?
              Also, I still need an all purpose cleaner that I can find in Canada. I can't find Purple Power here. Will any cleaner/degreaser work on my interior?
              Thanks for all your help guys. I'm kind of new to this stuff so I ask alot of questions.
                Hi 240X,yeah,just the normal auto shampoo.i normally use the soft gel which has a pink color.you should be able to find at least one of Meguiar's shampoos.i can't give you advice on a particular product,as i don't live in Canada.If you're unsure about a particular product,test it on a small hidden area and see how it works.What kind of dirt are you dealing with here? Cigarette tar,oily contaminents,etc,etc.......It sounds severe to me,if soap can't deal with this.
                keep in touch.
                  keep in touch.
                  I actually have a case of Mother's soap laying around somewhere so i'll give that a shot.
                  The dirt is pretty much just many years of human neglect and alot of dust. I'll give the soap a shot this weekend, and if that doesn't work then i'll have to look for something stronger.
                    I havn't heard of that soap.If you really have trouble getting a hold of Meg's interior cleaning products then you could try a couple of squirts of ('Grassx' in Italy) mixed in with the bucket of soapy water.you should be able to find this in any supermarket.It's basically a heavy duty dish soap/degreaser.Again,test it on an unseen area to dtermine if it will cause any discoloration etc.. Over here it's a flourescent yellow and comes in a spray bottle...but in another country could be a different colour and name.
                      Basically yes, just get/mix some "cleaner" and work a small area and see if anything what happens to the plastic/fabric.
                      ALWAYS DO A TEST SPOT
                      Thanks for all your help guys. I'm kind of new to this stuff so I ask allot of questions.
                      We we're all new at some point.
                      So post away! Some of use have no lives! (not me, I've very busy! !)
                        I would try to find Greased Lightning Orange Blast. It would come in a bottle something like this:
                        or this:
                        You can usually find them at Wal-Mart (I assume you do have a Wal-Mart, don't you? ) in the automotive aisle. Leaves a nice orange scent, and it's not overly strong. Hope this helps!
                          QID is for light cleaning, not removing built-up grime and dirt. You would like QID AFTER you do the initial clean-up to maintain the interior.
                          See product recommendations below. I'm assuming your 240SX has a vinyl interior?
                          QID is a LIGHT cleaner. Simple Green is an aggressive, heavy duty cleaner and you could cause damage if you use it incorrectly. (Test in an inconspicuous area first).
                          QID is like QD only for the inside, that is it's for removing fingerprints, dust and smudges off of about any surface except for glass and fabrics/cloth.
                          The Canada Meguiar's website lists this product,
                          M39 Vinyl Cleaner
                          Hands down one of the best cleaners for dirty vinyl on the market. It's the twin product to M40, so first you clean with M39 and then you condition and protect with M40
                          This would be a great comb to clean and restore any vinyl, plastic and rubber in your car.
                          M3916 Vinyl Cleaner
                          M4016 Vinyl & Rubber Cleaner/Conditioner
                          Both of these products have been around for 25 plus years and have a very strong and loyal following meaning you wont' be treading into unknown territory trying them out on your car.
                            Clean your interior with water/woolite mix 10:1. Then use #40 to protect the interior
                              So does M40 do the same thing that 303 Aerospace Protectant does, because I was planning on using that.
