Different Foam pads - what's the difference?
  • Different Foam pads - what's the difference?
    Hey guys,
    What's the difference between Meguiars yellow foam pad, and the purple ones that come with NXT 2.0? Does one have more bite than the other? Can they both be used to apply waxes, sealants, polishes, etc?
    Thanks!
    Jeff
    Re: Different Foam pads - what's the difference?
    Are you talking about pads used with a DA or the small ones used by hand?
      color, I'm sure there's no differance.
      Soft Foam Applicator Pads (Two Pack)
      "Meguiar’s Soft Foam applicator pad uses a tight cell, ultra soft foam for smooth application on all surfaces including leather, vinyl, and rubber."
        I'm looking at them both side to side and other than the color they seem to feel and look the same. Yes you can use them both for the uses you listed. But i always seem to use the purples for LSPs and the yellows for polishes.
        Alex C.
          The small applicator pads..
            I think Mike Phillips said they were the same except for the color.
            Dave
            You repair things with tools. You fix things with a hammer.
              As far as I can tell there is no difference between them at all besides the color, I will look and see if I cant find a reference for you
                Here it is, just scroll down a bit to find Mike's response Difference between pad color
