Usually when an egg is thrown against paint the impact of the hard shell against the paint chips the paint and leaves chip imprints behind. Looks like of like this,
The above is very hard to fix and make look good because you have to only put touch-up paint into the actual chipped spots.
If when you look at the paint where the egg hit and you only see a surface stain or discoloration then you can probably remove it by rubbing the area with a paint cleaner or compound like either our ScratchX 2.0 or Ultimate Compound.
Most auto parts stores will carry these products and be sure to pick up some extra foam applicator pads to apply the ScratchX 2.0 or Ultimate Compound, and to also apply some car wax when you're finished removing the stain.
