need help with rubber around back glass
  • need help with rubber around back glass
    I have a 1999 Ford Taurus and the rubber around the back windows looks chalky and dry. what product can I use to clean and restore and protect the rubber that is exposed to the elements?
    Re: need help with rubber around back glass
    Call up Rick @ ADS and order a bottle of Meg's M39 to clean and M40 to condition/protect.....if they're not too bad you can just use the M40 as a one-step as it does clean up mild wax residue, polish splatter, and contaminants. The M39 knocks out the heavier stuff like oxidation, etching, etc.
        M40 is a great product! As is All Season Dressing or Gold Class Trim Detailer.
        Give it a good cleaning and a couple applications of M40, letting it "soak" a moment then final wiping should do the trick!
          My daughter has a 95 ford Taurus. On her's I applied a liberal amount of All season dressing. let it soak in for probably a hour. Removed any excess. It was not a magic cure. But it did improve the trim.
