Can i use WHEEL BRIGHTENER in all weels , spray it on the weel then wash with water?
Wheel*brightener
Re: Wheel*brightener
No you cannot use it on bare aluminum wheels. If they are clear coated aluminum then yes, but make sure there are absolutely no chips in the clear coat or it will mess up the wheels.
Remove swirls my friends.
but I need a professional products instead of consumer because I will not use the gold class all wheel cleaner for my car but for my customers
So which product you recommends.
Bbeside that I am confused now about the useag of wheel brightener coz some ones told me that it can be used to clean the wheels and engine !
Meguiars APC then, would be my next go to, usally diluted 4:1, would be safe at 3:1 also. Very cheap for a gallon, I can get it locally for 13 dollars, works very well.Fergy-
there are also not going to be a whole lot of spray on, rinse off wheel cleaners out there that are safe on all wheels. I have had no luck finding any kind of cleaner that didn't need some type of agitation from a brush or two...IMOFergy-
1,2,10, a 100 uses.
Meg's APC really is an All Purpose Cleaner. I use it A LOT. On tires, rims, wheel wells, engine, undercarriage, carpet, headliners, steering wheels..... it goes on and on. I find a lot of uses for it around the house as well. It's good stuff.Alex C.
