Gold Class trim detailer on Matte Black "PAINT"
  • Gold Class trim detailer on Matte Black "PAINT"
    I've seen the recommendation to use Gold Class trim detailer on matte finishes but the bottle says do not use on paint?
    Will it damage the paint or is that a just a warning that it will not work to it's fullest potential on a painted surface?
    thanks,
    fred
    Re: Gold Class trim detailer on Matte Black "PAINT"
    answered...thank you
      From your similar question posted here,
      Need cleaning help on Matte Black Ducati!
      Originally posted by fbristow View Post
      It says on the bottle of the gold class trim detailer not to use it on painted surfaces.
      can you still you it on the tank or other painted parts?
      That's correct.
      If you read through this thread which is linked to above,
      How to create a dark sheen on flat black plastic
      It explains your options and the reality of flat black surfaces.
      But you are correct, as stated in the above article, Trim Detailer is not for use on paint. Contact the manufacture and check with them as to what they recommend you use to clean it and what you use to maintain it's appearance, and/or restore improve the appearance over time.
        thanks,
        fred
        It ***** that MEGUIARS OR ANY OTHER WEBSITE don't explain WHY its not good on paint, SO, in the case of "live and learn", I'm presently applying it to the back hood of my Mustang.
        NO OTHER SITE ON THE INTERNET EXPLAINS "WHY NOT TO APPLY THE "TRIM DETAILER" ON PAINT", SO I GUESS SACRIFICING IS WHAT I GOTTA DO!!!
          Well it's common sense. It's not a wax, compound or sealant.
          It is a trim dressing.
          Other things that shouldn't be used on paint that aren't explained are Dressings, window cleaners, oil, cornflakes, basil, garlic and the like.
          Why are you so upset that things that shouldn't be applied to paint aren't explained?
          Again, common sense.
          Read the label.
          Here's the simple explanation on why you shouldn't apply a trim dressing to paint.
          it's not a wax.
          it's oily.
          it's going to make your paint look like an oil slick.
          it's made for plastic and not paint.
          DetailingByM.com
