Ultimate Quick Detailer.......
  • Ultimate Quick Detailer.......
    Hei
    Im new with this, and in a explanation with this product it says you can use this between every wash.
    Im not sure what that means.
    So does it mean i can just wash the car and den spray this on and wipe it away?
    Or do I have to wash the car and dry it b4 i start with the quick detailer?
    Re: Ultimate Quick Detailer.......
    Some People use Ultimate Quik Detailer to help them dry.
    But I would dry first then use it.
    But if you are going to use it after you wash, I would buy Ultimate Quik Wax.
    But if you are going to use it for dusting jobs, in between your washes, Ultimate Quik Detailer is the way to go.
      UQD should be used to remove light dust.
      If the car is very dirty it should be washed but after a wash the UQD can be used to increase the gloss.
      Black Bart
        So with the Ultimate Quick Wax, do I have to dry the car after wash before starting with the Quick Wax? Or can I put it on on wet and dry circumstances?
          For best results Dry the vehicle before using either product.
          They are not "wax as you Dry" type products.
          Matt
            i just finished my first detail job with my new meguiars polisher!!!!
            this was on my own silver car.
            clayed
            swirlx on top, hood , and trunk only.
            colorx on all surfaces
            nxt 2.0 ( 2 coats)
            so my question is , should now give it a shot of UQD to top it off ?
            oh by the way , it turned out just great for my first time !!!
            thanks, roger
              i would just use the UQD:
              -after a wash/dry routine, or spritz on while you are drying.
              -to get dust and fingerprints off
              but you can use it how you wish
              2008 Toyota Corolla 5-spd
              2005 Honda CRF250R
              2002 kawasaki Ninja ZX9R
                Yes. Wash and dry the car before using the UQD
                Same for Ultimate Quik Wax. Paint care products work better on dry paint.
