Da?
  • Da?
    Not to sound uninformed, But a DA is polishing/waxing machine right!!
    Re: Da?
    DA is a specific polisher, a Dual Action Polisher that most detailers and members here use, followed by rotary polishers for more advanced work like removing wetsanding marks.
    Machine Photos - DA Polishers - Rotary Buffers - Traditional Orbital Buffers
      Re: Da?
      Are they expensive? Hard to use? Thank's for the answer!! I did not want to sound stupid!!
        Re: Da?
        They're not hard to use once you learn a little technique. There is a DVD you can purchase titled "How to use the PC for Showcar Results"
        DA's run about $150 new, but you can try to find one used. This guy may still have some for sale:
        Craigslist Ad: Meguiars G110 Dual Action Polisher Like New!! - $85.00
          Re: Da?
          Thank's! I was always afraid of leaving swirl mark's or burning the paint.
            Re: Da?
            Also:
            And yes, that DVD is a must have. It shows the G100 model, but the G110 is very similar. It also shows a good bit of working by hand.
              Re: Da?
              If you read the threads the others have mentioned and get the DVD. The chances of you burning through the paint are very slim.
                Re: Da?
                I read once if your using a DA, you can burn the paint if you soak the pad in lighter fluid and light it as you polish (Kevin Brown quote).
                  Re: Da?
                  What??
                    Re: Da?
                    thats a good one.
                    Dont worry MrWaxer thats a joke.
                      Re: Da?
                      yeah, it was a joke, a fellow member was worried about "burning" his paint and with a DA (not rotary) bout the only way you can burn the paint is if you do what I said . You can haze the paint or end up with results you may not like but not burn the paint
                        Re: Da?
                        Originally posted by PuDeN View Post
                        thats a good one.
                        I thought so.
