Some how my moms car has over spray on her windows i have no clue where it came from.... clay bar didnt work, neither did the rotary with ultra cut compound and a compounding pad.... whats next?
overspray on windows!!!! help!!!
Tags: None
Re: overspray on windows!!!! help!!!
If it's on the glass... do you think it might be on the paint also?
That is, if some type of overspray is drifting in the air and lands on the glass, is is possible it also landed on the paint?
Maybe feel the paint and see if you feel any overspray on the paint too...
As far as removal goes, is it possible to backtrack and troubleshoot where the overspray came from?
its been there for a while, and i dont know where she drove.... on the paint, clay bar, some cleaner polish, and some wax did the job.... see her car is white so not that much heat is created on the surface, but her tint is 5% straight black, thats my guess as to why it came off on the paint but not the windows...
Originally posted by pampos View Post+ 1 on that.And clean often the blade
1.) I was spray the glass with a spray type detailer
2.) take a NEW razor blade and hold it at an angle
3.) Move in one direction making sure to keep the surface wet with detailing spray, Light pressure was better, it doesn't take a lot to remove the over spray and using too much pressure and you're probably going to gouge the window.
I've done it several times and had really good luck doing it without damanging the window. But it only takes a few times to learn an extra ten minutes of masking will save hours of clean up time
Good Luck!!Red 99 SS Camaro - 578 RWHP 611 FT/LBS
"..If you do not strive to be the best at what you do, why do it at all?"
