I talked to you and forgot to ask should I follow up my hood and trunk with swirl-x after utlmiate compund or will the 205 work fine? Want to finish up but not sure please let me know thanks George.
hey Mike do I need to follow up with swirl-x?
Re: hey Mike do I need to follow up with swirl-x?
Every paint system is different as are each person's goals.Originally posted by nitrovette View PostI talked to you and forgot to ask should I follow up my hood and trunk with swirl-x after ultimate compound or will the 205 work fine? Want to finish up but not sure please let me know thanks George.
If the paint looks GREAT to you after the M105 you could go to wax at this point.
If you have M205 then definitely do a test spot and see if it's increasing gloss and clarity and if so then use M205 as your next step. After that go to wax.
In most cases, after M105 you would use either M205 or SwirlX but not both. They are both light cleaner/polishes with M205 being the less aggressive of the two.
