Spreading liquid waxes.....
  • Spreading liquid waxes.....
    Gang,
    (Boy I'm going to sound like a NooB). I got some M16 this last year. I discovered when I used it, I controlled the amount of product I put on the paint. I was able to easily remove except a couple of places I laid it thick while breaking the can in. Since then smooth sailing.
    With that, I learned I like paste waxes over liquid as I had troubles spreading the wax thin with liquid (with exception to the tail end of the spreading)
    Do you all "kiss" the paint with your pad when spreading the wax. I apply by hand and tried once with my G100 and didn't like it a whole lot and prefer hand.
    Would it be better to put about a teaspoon or so on the applicator and kiss the paint then spread it? I have a ton of liquid waxes that I enjoy (M21, M26, GC, NXT 2.0 among them) and don't want to put them on the back burner while I use paste.
    Thanks for the input.
    Aaron
    Re: Spreading liquid waxes.....
    I always use the "kiss" method when applying liquid wax. I start out with a smaller area then the 2x2. Then as my pad is sufficiently wet I go over a bigger area. This gives me the thin coat that is ideal. I (knock on wood) have had no problems doing it this way.
      When I "hand wax", I simply use a paste wax whenever possible. That keeps it simple.
      Tom
        ...Do you all "kiss" the paint with your pad when spreading the wax. I apply by hand and tried once with my G100 and didn't like it a whole lot and prefer hand...
        Nap, I run into this duality of techniques every time I do a silver or metallic colored car as I layer Pinnacle SSII over NXT/2.0 liquid wax. I use the "kiss" method for the liquid NXT/2.0 and as other posters have mentioned I start doing smaller areas until the pad is thoroughly primed and then move to larger panel areas at a time.
        The SSII is a true wipe-on/wipe-off product so it goes on and off wet and allows for total control of product amount on the surface with no removal issues. When I do the dark colored cars I layer the Meg's Gold Class paste. As you stated the thicker paste allows me to have more control over the amount applied.
          Groovy, seems like "kiss" the paint is the way to go!
          Thanks for the input guys.
          I have so many good waxes and want to use them before they go bad.....
            I have been looking at some videos on utube about spreading waxes.
            Would Meguiar have a tutorial video on wax spreading ?
              I just posted this in another thread. Figure it's germane here:
              I have a bunch of MF apps, but I rarely use them anymore. I've found that I get better results using the foam apps by "loading them" with product initially, and then using much less than normal when adding more.
              For example: let's say I'm applying some NXT 2.0 liquid. I'll take a clean foam app and put a bunch of product on it, and then rub it in to the pores. I do this until the entire yellow pad is that pinkish-white NXT color. Then, I add only a little when necessary. Once you get the hang of it, it yields great results, and I think that I end up using a little less product. There's definitely better coverage on the first couple panels--I know that for sure. I was inspired to do this by the KBM of prepping a pad. Same principal, same great results
              -Will-
              CDO ATW
                Nice tip...will have to give it a try on the next detail I do...
                  nice, as i was reading this I was going to mention, sort of like priming a pad using the KB method but you already mentioned it.
                  I will have to give it a try too.
                  Thanks for the tip
                  2008 Toyota Corolla 5-spd
                  2005 Honda CRF250R
                  2002 kawasaki Ninja ZX9R
                    the KB method is proving very beneficial in all areas of detailing
                    Fergy-
                      Yup, just waiting for his paper to finally be published at autopia
                      2005 Honda CRF250R
                        What is the KB method?
                          priming the pad with product before using. Someone will chime in here in just a lil bit to probably all of the different threads about the method.
                          Fergy-
