I have a black car with small scratches and am not sure what would be best to use to remove them using a G110 ? swirl x, scratch x or uc, or m-205 have clayed it and am ready to the next step have never used a DA so want to start slow so any help guys?
Removing small scratches?
Re: Removing small scratches?
Meguiar's always teaches,
"Use the least aggressive product to get the job done"
The key factor to a scratch is its depth. The way you remove scratches is to remove some paint off the surface until you level the surface with lowest portion of the deepest scratches.
From Hot Topics
So start with SwirlX and one of our yellow foam polishing pads and polish out a section about 16" square or so... then inspect your results in good lighting and see if the defects you're trying to remove have been removed as compared to the paint surrounding your test spot, and then make sure the paint is clear and glossy. If it is, you just dialed in a process you can successfully use around the rest of the car. If you're not seeing the results you want then post back here what you're seeing.
Be sure to read these,
How To use: G110 - G220 - G100 - PC/Porter Cable - UDM
If you're moving up to machine polishing, be sure to read the below thread before starting...
Tips & Techniques for using the G110, G100, G220 and the PC Dual Action Polisher
(These are all similar tools)
Cleaning Your Pad On The Fly
Which products need to dry before removing?
How to tape-off a car
How to apply product to the face of your foam buffing pads
The Swipe Test
Final Wiping Techniques
How to maintain your car's finish in-between polishing sessions
How-To capture swirls, scratches, etchings and other surface defects with your camera
Then go do some of this -->
Well did my hood and truck area today had to go over it 2 times each ,it does shine a lot did not get all the small scratches out but it does look good ,very shiny can you please tell me which would be better to use as a polish? #7 or 105 got a sample of 105 with my DA and was just wondering ? Thanks for all your help.
Originally posted by nitrovette View PostSorry meant 205
M07 is a non-abrasive polish for maximizing glass and clarity and bringing out the full richness of color for a single stage paint.
For what you're doing, following M105 with M205 would be the correct procedure. Be sure to use a clean foam polishing or finishing pad with the M205
Pictures?
Originally posted by nitrovette View PostWell did my hood and truck area today had to go over it 2 times each
Originally posted by nitrovette View PostShould I use 105? Or just use the 205 and wax?
