How can I remove that UGLY wheel weight adhesive left behind when the wheel weights are removed? I have 5 spoke 18" wheels and the adhesive is very noticeable.
Wheel weight adhesive
Re: Wheel weight adhesive
I let some goo gone soak into the foam for a while then it usually comes right off. A little more goo gone on a rag cleans up any remaining adhesive. Then clean with soap and water.1992 Mustang 5.0L turbo notchback
1986 Merkur XR4Ti 2.3L turbo
1998 Explorer 5.0L
Originally posted by twuckman View PostHow can I remove that UGLY wheel weight adhesive left behind when the wheel weights are removed? I have 5 spoke 18" wheels and the adhesive is very noticeable.
TL
You could also try vegetable oil - it usually will break down adhesive residue with a little passion behind the cloth. Or WD40 or similar lubricant/rust repellant type fluid.
I would try any of those before taking anything with a sharp edge to a wheel or any other delicate surface.
Had a similar issue with some used wheels purchased for my Vette...used one of those plastic scrapers/painters tools and some WD40. Followed up with wheel cleaner, then soap/water, and finally wheel wax. Came out perfect with no marring/etching/scratching imparted to the wheel surface.
Originally posted by roushstage2 View PostTook me hours to get the adhesive off of mine, wish it was a 30 second job
I now use regular lead weights but only get them put on the back of the rims. Works much better.Current Jeep: 2004 Jeep Liberty with stuff
Originally posted by Mike PhillipsLive on the edge... try something new, try NXT Tech Wax 2
