Just curious, could you use 80/83, Swirl X, etc... On the windshield to remove some faint scratching and stuff or is it worthless to even do? Just thought about it and thought I would ask.
Could you use paint cleaner on glass?
Re: Could you use paint cleaner on glass?
Paint polishes are not hard enough to even touch scratches in glass. If you search for "polishing glass" or "glass polish" you will find many threads including some with posts today.
Here are a few to get you started:
Glass polish
Glass polish #2
You can use it on glass
It will remove on surface contaminates, not scratches
You need something harder then the glass to remove the glass around the scratch, thus "removing" the scratch.
Here's my posts and others on the subject
Lake County-Glass Polish System
Removing scratch/blemish from windshield help
Originally posted by invertalon View Postto remove some faint scratching and stuff
As others have mentioned, paint cleaners won't do anything for scratches in glass, but for bad water spots and other similar issues M04 Heavy Cut Cleaner has long been a popular product. Ultimate Compound and M105 should work well for those water spots too.Michael Stoops
M04 works pretty well because the diminishing abrasive is fairly large and chunky, this allows it to cut into any film of gunk built-up on the surface of the glass without scratching the glass as it's being worked.
Products like M83, M82, M09, old ScratchX, etc. use microscopic diminishing abrasives and this lack of size and chunkiness inhibits their effectiveness.
M04 or M49 in the Marine Line work pretty well.
Could you use a clay bar and get the same results since you are just trying to remove surface contaminants?
Remove swirls my friends.
Originally posted by andrewc_11890 View PostCould you use a clay bar and get the same results since you are just trying to remove surface contaminants?
From my experience, based upon detailing hundreds of cars in Oregon and Washington which are exposed to a lot of rain and road grime, removing the kind of gunk or film-build that builds-up on glass on daily drives usually takes some muscle. Again, that's where the chunkiness of the diminishing abrasive in M04 excels compared to clay or things that are smooth and creamy.
Make sense?
It's really one of those things that when you feel the chunkiness of M04 and you go out and try to polish glass with horrible film-build on it, that you will fully understand and appreciate the difference in how abrasives work.
Over the years there's always been these kinds of discussions on this forum and others, but it's when you push away from the keyboard and actually go out into the garage and start working products over contaminated glass that the typed words have more meaning.
