is it fine to use soapy water as a lubricant?
Clay ?
Clay ?
MY NEW WORD "SWIRLFREENESS"
FOR ANY CHRYSLER 300/DODGE MAGNUM/DODGE CHARGER/ DODGE CHALLENGER VISIT WWW.LXFORUMS.COMTags: None
Re: Clay ?
ok well the plan was to wash..... then clean out bucket and use some soap and a little water and wet surface then clay....that should work right?>MY NEW WORD "SWIRLFREENESS"
Re: Clay ?
Originally posted by cm2005300 View Postok well the plan was to wash..... then clean out bucket and use some soap and a little water and wet surface then clay....that should work right?>
The safest bet is to fill a spray bottle with soap and water, or use a cheaper detailing spray like Last Touch diluted 1:1 or the full strength classic Quik Detailer.
Re: Clay ?
Just to note, there is no Meguiar's official recommendation for this you're on you're own if you use soapy water.
That said, this topic comes up often enough that it's a popular thread in our Hot Topics forum. (lot's of popular topics in that forum group)
3 pages long, that should just about answer any question related to this topic...
Are there any inexpensive lubes to use while claying?
Re: Clay ?
Originally posted by Mike Phillips View PostJust to note, there is no Meguiar's official recommendation for this you're on you're own if you use soapy water.
Re: Clay ?
Ha great i knew i wasnt the first to askMY NEW WORD "SWIRLFREENESS"
Re: Clay ?
yea mike one thing i didnt see mentioned in that link was you said soapy water is not good to leave just " wiped off" but if you rinse the panel throughly afterwards then shouldn't it be fine?MY NEW WORD "SWIRLFREENESS"
Re: Clay ?
Clay will deteriorate more when you use soap and water as a lubricant, in my experience anyway. I would suggest you use either final inspection or QD.
Andy M.Keeping MOL family friendly! If you need help or have a question, don't hesitate to shoot me an email or PM. 101impala@gmail.com
Andy M. Moderator
Re: Clay ?
Originally posted by cm2005300 View Postyea mike one thing i didnt see mentioned in that link was you said soapy water is not good to leave just " wiped off" but if you rinse the panel throughly afterwards then shouldn't it be fine?
Originally posted by Andy M. View PostClay will deteriorate more when you use soap and water as a lubricant, in my experience anyway. I would suggest you use either final inspection or QD.
Andy M.
Re: Clay ?
ok thanks for your help guys!!MY NEW WORD "SWIRLFREENESS"
