Question about my G110
  • Question about my G110
    Hi im kyle
    I have a little question
    I only have g110 so how do i use that to remove the Swirl ?
    How much pressure should i use ?
    Re: Question about my G110
    I would use a polishing pad, on 3-5.
    I would use moderate then shifting to light as the polish gets worked out.
      If you have Swirl X available to you, try that with the suggestions above. If they are really bad you might need to step up to something more aggressive, but start there first.
      What kind of car is it?
      2018 Subaru Outback 3.6R Touring - Crystal White Pearl
        Yeah if SwirlX isn't available, you can use the old ScratchX too.
        -HealthyCivic
        Check out the glossary
