bird mess
  • bird mess
    Hello,
    I have a 1988 black monte carlo ss that has some stains on the paint from bird droppings. Is there any way to remove them without harming the finish?
    Re: bird mess
    Technically, the acid etching from the bird droppings have already damaged the finish. The good news is you should be able to remove the damage, it just depend what products and methods you will need. Could you add photos of the worst damage so others can lend their experience and advice?
    How To Remove a Bird Dropping Etching by Hand using M105 Ultra Cut Compound
      Re: bird mess
      You can also use Ultimate Compound or ScratchX 2.0 both of which you should be able to find at your local auto parts stores,
      Click on the images to go to their dedicated threads...
      Swirl and Scratch Removers
      Ultimate Compound
      ScratchX 2.0
      SwirlX
      Most aggressive to least aggressive -->
      Be sure to pick up some of these to apply whichever product you choose to use,
      X3070 Soft Foam Applicator pads
      After you work the etching out, be sure to follow the paint cleaner with a coating of wax.
      Do you know how to correctly apply a paint cleaner?
