Dusting the interior
  • Dusting the interior
    What is the best way to dust the interior so you get all the dust out? I've tried using a dash duster, a microfiber towel, compressed air, whatever. That gets most of the dust out but there's still always that little bit of dust left that just drives me nuts . Would Quik Interior Detailer help at all? Any thoughts or suggestions would be greatly appreciated.
    Re: Dusting the interior
    i would use Quik Interior Detailer and a microfiber and since your trying to remove all the dust then lightly mist the QID on the surface.
      Hey, the easiest way to pick up dust is to use Quik Interior Detailer and a Microfiber towel. It cleans and protects your interior at the same time. For hard to reach areas such as the AC Vents and cracks, get some small Detailing brushes for those areas
      Hope that helps
      Matt
        Remember to vacuum very well all the seats and carpets as well
          QID sprayed on a MF towel or soft brush seems to work quite well. Also checking the cabin air filter if needed.
            Compressed air used safely works pretty good.
            Besides that first try to vacuum as much dust as you can out so the dust, which can be abrasive goes into the vacuum filter bag and not into your microfiber polishing cloths.
            After vacuuming, wipe everything as good as you can using terry cloth towels instead of microfibers, it helps to have a thick nap to trap and hold dust. Using G13616 Quik Interior Detailer to dampen your towel will help to hold the dust onto the towel also.
