Detailing question
    Re: Detailing question
    Thanks Mike. So I guess I will pick up some Ultimate Compound. It looks like our local Walmart carries it, so I will check there. I guess I should pick up a clay bar then too ahh? What other products do you recommend for me to finish the job up with?
    Has far has washing I have the Gold Class car wash and shampoo so I guess I will use that first then the compound, then clay bar, then.....
    Dedicated Soldier:
    AD Infantry 11C 2000-2004
    FT PA National Guard; AGR 2006 +
      Wash
      Clay
      Test Spot on hood with the compound and then inspect the results.
      If the finish results look good in your Test Spot then
      Wash
      Clay
      Compound
      Wax
      If the finish results look good but there's some light haze in your Test Spot then,
      Wash
      Clay
      Compound
      SwirlX
      Wax
      Try to keep it simple especially if this is your daily driver.
        Thanks Mike. I will follow that method. This vehicle is not my dail, but rather my summer (nice day) cruiser so I can devote time to doing it right
        Much appreciated sir. I'm going to take pictures of my before, during and after then post The cars white so it won't look has nice has a colored car but I am SURE there will be a big difference
        Dedicated Soldier:
          If I order the Power kit, item # Kit2, which is a buffer and some pads could you (Mike) explain to me what products to only apply to what pads. For instance the polishing pads. I'm guessing I could use swirl x on them but can I use compound or do I have to buy the 2.0 cutting pads? On the finishing pads do I only use wax? How long do the pads last and do you have to swap them out while working on one vehicle?
          such a noob I am
          Dedicated Soldier:
