where to position lights?
  • where to position lights?
    I have a white dodge charger that has some light/medium swirls and i will work on them using a DA polisher and M83 / M80
    I also bought a 500 W dual halogen light.
    I noticed that when the car is under the sun i can easily see the swirls but at night when lighting the car with the halogen lights is difficult to really see all the swirls i see under the sun.
    I know the withe color doesn't help to spot the swirls but is there any trick on where to position the halogen lamp to better see the swirls?
    Re: where to position lights?
    Did it come with a stand?
    I just use the halogens slightly off to the side and start polishing where the light is focused. The light is far enough back that it doesn't heat the paint, though.
    Chris
    Dasher Detailing Services
      Im just curious, and not to thread jack but does it matter on the wattage?
        Some halogens are rated at a higher wattage, but they have more bulbs.
        For example, my 1300w work light has four bulbs (two 500w's and two 150w's). Others just have two 500w's.
        A brighter light can help detect more defects, but they cost more.
        The only reason I purchased the 1300w setup was because they were out of the 1000w. But, I think the 1300w really shows everything.
        Chris
          ^ How do you get your camera to focus on the paint and not the reflection of the lamps?
          I have a point and shoot.
            See if you can one of these and when you use it hold it about a foot to a foot and a half away from the paint.
            Last time I was in Pep Boys the had the exact Brinkman Flashlight you want to get for around $25.00
            Here's what you're looking for...
            Be wary... the Xeon Flashlight aka The Swirl Finder... is a Cruel Master
              I use one of two techniques. Either point your finger to the paint (touching the paint) and let the camera focus on your finger or the better way is to lay a piece of tape on the paint's surface and try to get the camera to focus on the tap. That will show the defects (or lack there of) the best.
              Dans Tech Reviews | Wii Shopper
                There's actually a thread on this technique here,
                How-To capture swirls, scratches, etchings and other surface defects with your camera
                  Wattage really doesn't matter. I have a single bulb 150w Halogen that shows everything. Those Xenon Hand Lights are nice for taking pics, but you can't have them on while polishing.
                  You just have to find the right angle where you can see the swirls.
                  Read Mike's link as well
                  Matt
