Polishing oils in DC Polish and #80?
  • Polishing oils in DC Polish and #80?
    What is a better polish as far as oils and appearance go? I know everybody is pretty fond of #80 being the last step before a LSP, but how does DC Polish compare to it? I know #80 can be used for corrective work as well, where DC polish cannot, but I am just looking at the "polish" aspect of each product.
    It is getting close to my big spring detail and want to go all out adding in a pure polish step. I was just wondering if #80 or DC Polish would give me a better look? I know there may be better pure polishes available, but I want to use up what I have first! haha
    Appreciate it!
    Re: Polishing oils in DC Polish and #80?
    DC2 is a pure polish and has no cleaning ability whatsoever and M80 is a 4 on the cut scale and is a cleaner and a polish. So if you need cleaning ability and want a polish and want to go staright to wax after it then M80 would be more ideal because it cleans and polishes in one step. If you wanted to use DC2 then you would do your paint cleaning/correction first then use the DC2. They both are for different people, since DC2 is in the consumer line and M80 is in the pro line. But i believe M07 show car glaze has the most polishing oils. so either one will work fine as a polish
      I understand how #80 has a bit of paint-cleaner use in it, but as far as the amount of the oils inside, which has more?
        Both M80 and Deep Crystal Polish contain a rich content of polishing oils, if you want the polish with the richest content of polishing oils then pick up a bottle of M07 Show Car Glaze.
        What are you working on?
        What are you trying to accomplish?
          I will be washing, claying, correcting (#83, Swirl X, Scratch X, etc...), and then after that I want to lay a polish as my last step before my LSP. I know M07 is the go-to glaze, but I was just trying to use up what I have before I buy anymore (Just put down about $200 in Meguiars products for this summer!). So with what I have as far as polishes go are #80 and DC Polish. So between them, I was just looking for which offered a higher content of oils. If both DC and #80 are that close as far as the content, then I will probably just pick #80 because of how good it smells...
          Oh, and if it matters any, it is for a black sand pearl finish.
            if i had to make an educated guess i would say that M80 has more polishing oils than DC2, but then again i could be wrong , i do know that i have tried both and they have given me good results
              i think you should buy M80 rather than product that is a pure polish...because this is what I think, you never know what the condition of your paint after cleaning it with cleaning product such as M83, scratchX and so on, like in my car after i'm using M83 it leaves with micro marring than if i want a close to perfect finishing i can use product with little cleaning ability such as M80 but at the same time polish the paint too...it's just my oppinion
                good point, very true indeed
                  M80 is very rich in polishing oils so for what you've described you want to do, go with the M80, if applying by hand use a foam applicator pad and a gentle touch, if applying with a DA Polisher stick with the yellow foam pads.
                  Pictures when you're done?
