Bedliner stain removal
  • Bedliner stain removal
    Hey Guys,
    Every other wash I like to clean my Line X bedliner with Nxt Car wash and agitate with a soft brush.
    There is a stain a size of a quarter on the bedliner from waxing my roof with Nxt Tech Wax 2.0 and i spilled a drop of it on the bedliner
    Tried APC with an all surface interior brush
    should i try #39 with a tire brush?
    not sure what to do and want to use the least aggressive method as i dont want to make things worse
    Thanks in advance
    Re: Bedliner stain removal
    A stain like the white residue?
      yes, but i figured its an easy fix with APC but it didnt budge
        This is a pretty good product for removing wax stains.
        If you have the M39 maybe give it a try.
          Just went out to the garage and gave it a try its about 95% gone
          Heres what i did:
          Spray APC in affected area and agitated
          Sprayed M39 and agitated
          sprayed with water and used the blot method to dry as its very texturized
          Sprayed M39 and agitated for about 2 minutes
          then sprayed with APC and used blot method to dry
          waited 2 min for it to dry
          and it was almolst gone, might do a third application
          thanks for helpin me out
            Well at least it has budged!!
              I don't think you can hurt the Line-x so don't be afraid to go at it....
                Should be able to dress it afer as well.
