My girlfriends father was pulling into his garage the other night and ran the side of his van up against a support pole for his porch. It took the paint off the pole and "smeared" it up the side of the van. The paint is stuck on the side of van and is thick as can be. What can I use to get the paint off the side of his van. I'm sure there are going to be some pretty bad scratches under the house paint, but I'll deal with them later. The area of the paint is probable 8 or 9 inches high and probable a foot long and it is just covered.
Latex House Paint???
I'm not sure what our equivalent is in Australia, but if latex paint is waterbased its might be similar to our Acrylic or PVA. If that's the case then methylated spirits (an alcohol) can disolve it without removing automotive paint. Mind you, old dried waterbased paint will disolve very slowly.
Can't hurt to try...seems its big enough to not touch the cars paint...you'll need to saturate the surface.
Hope this helps.Paul Marmarinos
Re: Latex House Paint???
I would certainly not recommend using an alcohol based product. It would be much safer to use a paint cleaner like ScratchX.
I have personally had good results using a product called Goof Off followed by #6 Cleaner Wax. Here's a link to the Goof Off site; http://www.valspar.com/val/resident/goof-off.jspFRANK CANNA
Mirror Finish Detailing
23rd Year 1986-2009
