Nxt tire cleaner vs. APC
  • Nxt tire cleaner vs. APC
    I am going to be doing a simple wash on my truck tommorow followed by some Ultimate Quik Wax( expect a review with pics!)
    I usually use Megs APC with a Versa Angle tire brush to clean the tires but i got ahold of some NXT tire cleaner and wanted to know which is more effective to clean tires with. I was thinking NXT would be better because it is intended for that purpose, but then i have read a lot of ppl use APC. So what do you think i should do?
    Thanks guys
    Re: Nxt tire cleaner vs. APC
    Well, you have it, try it.
    But I didnt like the Nxt much at all.
      I used the NXT Tire Cleaner and I didn't think it cleaned as well, pretty mild stuff, maybe a couple of applications would do better.....
        Great Idea!!
        I can not wait.
        Is it going to be warm enough, or do you have a heat garage?
          Originally posted by Carfire View Post
          Great Idea!!
          I can not wait.
          i have a heated garage
            i think i will try NXT first then follow up with APC if neccesary
            thanks for your feedback!
              i just got all these products on Wedsday and will be using them on my detail on my truck tommorow, so far i am for sure doing writeups on the UQW and SSP
                Where did you find the wheel brush at???
                  when you use up all the nxt tire cleaner, you can purchase a foaming spray head for your APC bottle and it use it when you do the tires, etc...
                    APC is much better and cheaper as well....
                    Ryan
                      Do you recommend using a foam spray when using APC
                        Ryan
                        i think i will try NXT tire cleaner, then go to APC if neccesary
                          Cleanacar.com
                            I use APC on the tires (and a lot of other places) and it's great stuff.
                            Keep in mind the NXT is for consumers, so of course it's going to be milder than anything in either the Detailer or Mirror Glaze line.
                            Heatgain (Gary)
                            The Irate Magistrate
                            Neutral & Detached
                              I might be one of the few but I kind of liked NXT tire cleaner... Worked for me, that said I now use either APC+ or APC they are a much more versatile product allowing for less products sitting around the house. I am in the process of changing over to the APC's and eliminating my dedicated carpet cleaners/tire cleaners and so on making things easier!!
                              Brandon
                              2007 Black Chevy Avalanche
                              My Albums: Avalanche
