Ultimate Quik Detailer vs M135 ??
  • Ultimate Quik Detailer vs M135 ??
    Are UQD and M135 basically the same thing? Is one any better than the other, other than the fact I can buy M135 in larger quantities? Should I expect the same level of performance from both of these? I LOVE the UQD. It is one of the best products Meguiars has ever come out with. I go through at least a bottle per month. A product you can use on both glass and paint.
    Re: Ultimate Quik Detailer vs M135 ??
    Basically the same thing.
    I never tried it, my wifey found some UQD at Target for 2 for 11 bucks and got me a few bottles, but when those run out, I'm in for M135 after that.
      I might order some UQD and see if I like the scent any better.
        To add, I used UQD on glass and I had a buildup on both of my cars that streaked real bad and had to give them a royal scrubbing to get that off of them. I don't use it anymore on glass......
          That is weird because I use it on glass almost daily with no problems. I even use it on the inside of my windows. Shoot I cleaned my eye glasses with it the other day, probably a stupid question but are you using microfiber for the application. I noticed on Auto Detailing Supply they even mentioned using the M-135 on glass
            Please refer: http://meguiarsonline.com/forums/showthread.php?t=27899
            -----cut----
            Mike Phillips Administrator
            Oct 15th, 2008, 11:52 PM
            Re: M135 or UQD?
            They are basically the same product but they are sold into and marketed into very distinctly different markets.
            The benefit of M135 is you can buy it by the gallon.
            Pick the one you want and buy it and then use it and enjoy the results.
            There is at least one, if not a dozen threads on this forum with your question, but I'm not sure what you would use as a search term to find them.
            Great products, you're going to love the one you choose.
            -----cut----
              I ordered a bottle of M135 to give it a try and also some Final Inspection for my hood that was just painted. After trying both I think I like the M135 a little better. Has a more pleasant smell and seemed to make the finish even slicker. And I can order it by the gallon. The final inspection also seemed to work better than the regular quik detailer that you can buy at Walmart.
