Hi-Tech Body Sponge™
  • Hi-Tech Body Sponge™
    Nevermind. I should have searched. See these threads:
    Hi Tech Body Sponge vs. Clay bar
    Claying with "Hi-Tech Body Sponge"
    Hi-Tech Body Sponge: same idea as a Quick detailer?
    Everyone learn from my mistake and search before making threads on products that have been out for a while haha.
    -HealthyCivic
    Check out the glossary
    Re: Hi-Tech Body Sponge™
    There should be a review or two around here somewhere if you search, unless they were on the old forum.
      It works. If you rub it over paint with a lubricant it will remove above surface bonded contaminants.
      Personal preference plays a lot into whether you think it's good or not.
      Take one for the forum, order one, use it and then write a review!
        I used one on my wifes car with some last touch detailer ,I really liked the results.The paint felt nice and smooth.Topped it with some 2.0.
        barry
          my 2 cents,
          I like them, use them on harder paints and glass, they are great. On softer paints I notice scuffing of the clear though when using them, but if you're going to be polishing it afterwards, then it's not a big deal. They do work, and work well, but you need to use a little care as they can be pretty aggressive.
          Tom
            Can you use it as you wash a car prior to correction?
            I think I've heard of this being done.
            www.clean4udetailing.com
              I will usually wash the car, then redo my car washing soap, go over it again with the Body Sponge and rinse.
                Makes since.
                Wonder how it works with ONR AFTER the initial ONR wash.
                How many times can you use this sponge since you can wash it out?
                  Originally posted by justin30513 View Post
                  Makes since.
                  Well, it's supposed to work with any lubricant, and I have used it with Last Touch and it worked fine, but have not used it with ONR. I am thinking you could get about 12 vehicles out of it before needing to replace it due to the rubber strip wearing out. That's pretty dependant on how bad the vehicles are you are working on as well.
                  I will say that it does save me time, due to the car still being wet, and just changing the soap and going over the car again, not having to take the time to re-nead the clay and then just rinsing and drying, it's faster for me.
                  If I have a car that is in good shape, or will scratch easily, I will use the mild blue clay, but if I have something with lots of fallout I will use one of these sponges. I would suggest giving them a try, and let me know what you think. They work great on glass as well...
                    Going to pick up a few with next order (205/new 105) from ADS!
                    I'll post a write up and review.
