Removing Ink
  • Removing Ink
    There is some ink on the steering wheel of a car I am detailing. I tried using and standard cleaner but it just smeared the ink more. What do you guys use to remove ink. It is the standard Vinyl/plastic steering wheel material of most cars...
    Matt
    Re: Removing Ink
    The standard cleaner was APC?
    #39 seems like the strongest plastic/vinyl cleaner...
    Might be something to try a Magic Eraser on, or a bit of a soak and blot technique as well.
      Re: Removing Ink
      No i was using "other stuff"
      -Tuff Stuff
      -Windex
      -Lysol
      I will try Magic Eraser, I heard they work.
      If that doesn't work, I will try APC
      Matt
        Re: Removing Ink
        Hairspray removes ink from clothes, try it!
          Re: Removing Ink
          I would go with the APC first. Then try the hairspray. Good luck.
