First Detail w/G110
  • First Detail w/G110
    Just completed my first detail with my recently purchased G110. Took me about 9 hours.
    1. Gold Class wash
    2. Clay
    3. #80 w/8006
    4. NXT 2.0 w/9006
    Sorry for the poor picture quality. Had to finish up inside at night (raining outside) and don't have good lighting in my garage. Couldn't get any good pics of the swirl marks after, but, believe me, they were greatly reduced. (I have a Brinkmann, but couldn't figure out how to hold it and take a good pic at the same time...)
    Tried ColorX with an 8006 pad first and while it did remove some of the swirls, it wasn't as effective as the #80 (did not see any marring).
    Before swirl marks
    After
    I was particularly impressed with how easily the NXT went on and came off, even on a cold (40's), damp day. I had been using #21, but think I might actually prefer NXT, provided the durability is there.
    Great products, great results. Thanks Mequiar's.
    2013 Highlander - black
    2010 TL - black
    Re: First Detail w/G110
    Looks great. Nice reflections. Congratulations on your first machine detail. Way to go. Great job.
      Nice work!
      Machine polishing enables you do as good as work and often times even better work than your local detail shops because you're using better product and you care about work.
        Looks great nice work! Hard to beat the look a PC, the right products and the knowledge will give you. Very nice!!
        Brandon
        2007 Black Chevy Avalanche
        My Albums: Avalanche
          Thanks, guys. Appreciate your feedback and comments.
          2010 TL - black
            Nice Shine!
              Nice shine, looks great! That's the same combo of products I use, except I finish up with #26 instead of NXT.
              George Carlin
                great job.
                Try boost up your camera ISO when u take low lighting photos
                  Question:
                  The 8006 and 9006 pads ... what are they comparable with in the Lake Country product line (orange, yellow, white or black)? I just got in my #80 and plan on detailing my truck this weekend. All my pads are awaiting but I'm not sure which one(s) to use.
                  My guess is the white and/or black as they are the softest.
                  Many thanks ...
                    I like #26, too. I normally use it for my spring detail. I typically use #21 for the winter, but thought NXT 2.0 with it's durability/protection and hydrophobic ability might be worth a shot. I was very impressed with the gloss and depth, and am eager to see how it holds up through the winter months.
                    Thanks for the comments.
                    2010 TL - black
                      The car looks great! I love how easy NXT 2.0 is to use also.
                      dud... give #80 a try with the white pad. That's pretty close to 8006.
                      Scott
                        Great work there! congrats...
                        just wanted to know if you already have previous worked with a polisher machine or it's just your first time?
                        I ask you this, cause I want to get same machine and it's good to know your expierence with it, thanks and I apologize for my english
                        good bye
                          Thanks BlueZero, I will do that.
                          It appears that the concensus is that #80 is the best "all around" product for people who do not want to go through multiple steps before applying a final wax/polish. There seems to be a difference of opinion as to what the "best" overall final wax/polish product should be.
                            good bye
                            It was my first time with a PC type DA.
                            I have a 6" orbital polisher that I bought at Sear's about 1 year ago. It worked OK for applying wax/sealant, but with two black cars, both daily drivers, I needed something that had more power for removing swirls and blemishes.
                            I found the G110 to be quite easy to use. The backing plate is easy to attach. The machine weighs only about 5.5 lb. and the optional handle (which I used) helps provide good control, especially on the vertical surfaces. The variable speed settings allow you to optimize the polisher’s performance for the product you are using – lower settings for waxes/sealants, higher settings for cleaners/polishes.
                            Overall, a great tool. Very easy to use, even if you have no previous polishing machine experience. You can also purchase an instructional DVD if you feel the need. Would recommend you read this thread prior to using it.
                            http://meguiarsonline.com/forums/showthread.php?t=20874
                            Last edited by gjohn28; Oct 29, 2008, 06:05 PM. Reason: trouble with link to thread
                            2010 TL - black
                              Originally posted by gjohn28 View Post
                              it was my first time with a pc type da.
                              i have a 6" orbital polisher that i bought at sear's about 1 year ago. It worked ok for applying wax/sealant, but with two black cars, both daily drivers, i needed something that had more power for removing swirls and blemishes.
                              i found the g110 to be quite easy to use. The backing plate is easy to attach. The machine weighs only about 5.5 lb. And the optional handle (which i used) helps provide good control, especially on the vertical surfaces. The variable speed settings allow you to optimize the polisher’s performance for the product you are using – lower settings for waxes/sealants, higher settings for cleaners/polishes.
                              overall, a great tool. Very easy to use, even if you have no previous polishing machine experience. You can also purchase an instructional dvd if you feel the need. Would recommend you read this thread prior to using it.
                              http://meguiarsonline.com/forums/showthread.php?t=2965
