Pits in the W-9006 pad
  • Pits in the W-9006 pad
    Hi Mike,
    I've just noticed that there are fews pits in one of my W-9006 pads. Is it normal?? The pad is around two months old. Never washed and used a few times with #81. My question is that will the pits cause any fine scratch? Shall I keep using it or get a new one??
    Cheers
    Stephen
    Hi nx80v,
    This shouldn't be a problem or cause swirls. I've seen the same thing before once in a while.
    p.s.
    See if your camera has a White Balance function
      Mike,
      Thanks for your quick reply.
      By the way, my camera does has the white balance function. The picture was under-exposed because I've turned off the flash. Just too tired to fool around with the setting after my 12-hour shift.
      Cheers
      Stephen
