The Deep Crystal System is pretty straight forward.
First, of course, wash your car and then inspect with the palm of your clean hand for above surface bonded contaminants. If you feel any, then clay your car after washing, and before using the Deep Crystal System.
Next, apply each of three products in order, Step 1, Step 2, and then Step 3.
The most important step is the Step 1 Paint Cleaner, it is important that you apply this product thoroughly to insure thorough cleaning of the surface. It will determine your end results.
After that, the other two products are basically wipe on, work in products. The first two products, the paint cleaner and the polish you remove immediately after application and working in. The third step, the Carnauba Wax, you want to let dry to a haze, usually 10-15 minutes and them remove.
Typically use clean, soft foam applicator pads to apply all three products, a different applicator for each product, and remove with a plush, premium quality microfiber polishing cloth such as Meguiar's Ultimate Wipe, or a clean, soft, 100% cotton towel.
That's it.
Hope this helps...
