I buffed today
  • I buffed today
    I tired the SO10 product for the first time today! Seem to work OK for not doing any buffing for about 18 years. This is what I experienced with a clear coat that is 7 weeks old and wet sanded with 1500 grit only. I did the buffing under fluorescent lights
    1. Started with yellow wool pad, did not cut enough
    2. Went to the red wool pad, cut nicely but again not fast enough. I had to make several passes to get the sanding scratches out. I tired different speeds and pressures but it seemed to me I should be using a stronger cutting product, maybe because of the 1500 grit used.
    3. Tired the yellow foam pad, that was nice and left a very good finish even took a little more of the fine scratches out.
    4. Tired the black foam pad that was nicer yet.
    Now for my questions:
    • How long do you spend on a 2’ x 3’ panel section? When tying to remove sanding scratches? I worked on mine for about 20 minutes (trying different pads) and there is still some showing. Very slight orange peel too.
    • How much pressure do you use when buffing out sanding scratches?
    • Should I go over the entire car with 2000 grit or go to maybe the M95 or M105?
    • When using M86 how long do you work it? When haze is gone or just slightly showing?
    Any other advice is welcome. Other then the above all went well today
    Re: I buffed today-DOUBLE POST
    Sorry everyone double post.....
