How can i clean my wipers?My windshield smears when i use them and i think that the problem is not only on windshield but from wipers.Any suggestions?Thanks....
Well,my wipers is about 8 months and the problem that i have is when the windshield i dry.I have the All purpose cleaner and NXT protectand.I used to clean my windshield two times a week because i wash my car..
Well I like to get a microfiber wet with my window cleaner. Then I wipe down the wiper blade with the wet micro.. It does remove a bunch of dirt from the blade.
Ok,but if the micro is only damp with water, it will not remove the dirt from the wiper.I think that we must remove road dirt over the wiper with something.So it will not transmit on the windshield.
If you want to thoroughly clean everything, you can clay the window and then wipe it down with glass cleaner. As for the wiper blades, I will clean mine every now and then with some rubbing alcohol. You may have to go over it several times to get all of the junk off of them. 303 makes a treatment wipe as well for the blades that can be found sometimes at parts stores for about 59 cents or so.
Thanks you all!If i clean wipers with a micro fiber with apc and after with #40?I think taht the problem sometimes is that the rub on the wiper becomes dirty and tough.What is rubbing alcohol?
Sorry,J.A. Michaels....
You can buy rubbing alcohol at any pharmacy, also many car care stores carry small wipes that are specifically used for wipers (like a glorified handi-wipe with any aroma/perfume). These willl help to keep the rubber soft and pliable while also clean the blade. I do this at least once a week (I am very OCD about my windows/windshield)
I've never "washed" my wiper in any special way other than using what I use for the car. I always put a dressing on my wipers, it is rubber. I don't have any problems doing that.
I've done it for over 30 years on all of my cars.
I hate not having functioning wipers or wiper fluid.
