First carwash of new car that is. 2004 metallic silver Miata. Couple of issues. BTW, washed with Meguiar's carwash sol'n and dried with The Absorber. Is it OK to use Bug and Tar Remover without damaging finish? There appears to be a long adhesive line on both sides of car that does not come off easily. I think it's from protective plastic put on car at factory. I will clay and polish/wax in a couple of weeks. Is that best way to remove it? Finally, there is a roughened plastic-like coated area along bottom of both sides of car. How do I maintain this? I'm thinking only to wax it (and not clay or polish it). Any comments? Thanks,
1st carwash
Congrats on the new car! I'm sure she's a beauty!
Bug and tar remover on the adhesive strip probably isn't a bad idea but, I'd recommend that you test a very small area prior to ripping in to the entire strip. In short, apply a very small amount to a microfiber towel and rub it across the affected area. Immediately follow with a wet towel to remove any excess that may be on the surface. Do not apply massive amounts of direct downward pressure as this can mar or scratch the surface.
Also, I wouldn't utilize this product unless you're planning on waxxing the vehicle immediately after as any bug and tar type of product will remove protection.
I'm not familar with the plastic-like 'stuff' that you've described and thus, I think I'm going to leave that one alone and wait for someone to chime in that may know it better than me. My hunch is that your plan is okay but, I'd hate to advise you on something not knowing the entire scale of details.
RP
Re: 1st carwash
You may try call your salesperson to help you out. This will save some of your $$$.
New car from Mazda dealership. But i'd really rather not leave it for a day or two if it will come off with clay/cleaner/polisher/wax. I can pick it off with my nail, so it is not embedded.'08 MX-5 Miata GT - Highland Green Mica with Saddle Brown Ragtop and Leather Interior
Did you try or read this?
I have those deer alert devices on the front bumper of my car. They don't fit on the bumper very well but they do work for me. One of them finally fell off and there is a very sticky foam adhesive left on the bumper. What is the best product to remove this adhesive-backed foam tape? It is very stubborn. Too bad it didn't stick
Re: 1st carwash
There appears to be a long adhesive line on both sides of car that does not come off easily. I think it's from protective plastic put on car at factory. I will clay and polish/wax in a couple of weeks. What is that best way to remove it?
Thanks for taking the time to advise me, Mike. The bottom of the side panels (under the doors) is the same metal and paint as the rest of the car. It just has a thin coating over it to ? protect against stone chips etc. It is about 8" from top to bottom and runs from the front wheel well to the back one.'08 MX-5 Miata GT - Highland Green Mica with Saddle Brown Ragtop and Leather Interior
Try a spot and see if you see a difference. If it doesn't look worse, then it wouldn't hurt to apply something versus nothing I would think.
