In the course of polishing and waxing your car, how many pads for each product do you typically use? At one point do you know it is time to put on a new pad? TIA.
Al
--Al Kimel
Well, it varies by product, car size, and how much testing you need to do, but I would say that on average for a full paint correction with a multi-step compound and polish I would use about 4-6 pads.
I clean my pads regularly with a brush, towel, and/or spur though.
As for knowing when, basically it should start to feel REALLY saturated and change completely in color- as well as changing the way it glides across the surface. Sometimes you will notice a definite change in cut as well.
I clean my pads on the fly after every pass or at least every other past at times.
I typically use 2 pads for a dedicated product during a detail. I have a time or two, washed them and placed in the sun to dry while using the other pad, just in case. I now have more pads and have at least 1 dedicated to a product used most and a pad dedicated to each wax I use (NXT, M26, M21).
The nice thing about the cleaner polishes is the pads can be rinsed out and if you have a rotary, zip them on the rotary to "wring" out the water and they'll be dry shortly after that
I have a few extras on stand by for Polishes since they tend to gum up a little due to the oils and using too much product. Even if you clean them on the fly, you may have to grab a new one. Especially with a rotary.
