does Quick detailer remove Nxt wax?
  • does Quick detailer remove Nxt wax?
    just waxed the Viper. I want to take it out for a ride. When I come back do i need to re wax or use quick detailer or what?
    thanks.
    Re: does Quick detailer remove Nxt wax?
    As Mike Phillips recently suggested, any time you are touching the surface and NOT actually ADDING wax, you are in theory likely removing it. Just think on a super logical basic level...it's that easy. But, at the same time, have no fret...the quick detailers are intended to be used between waxes and the wax they *may* remove is minimal.
    If you are really worried, use a product like Ultimate Quik Detailer as it ADDS significant water protection and amazing deep gloss- just like wax! I use it probably 5 days a week!
      I would use the uqd also. As long as the car just has light dust and fingerprints. If the dirt is worse then that then you should wash. But for the very light stuff, qd it and your ok.
        And just to clarify, I was positioning things in the extreme because it seems there's a certain percentage of online enthusiasts that are extremely AR or as I like to say, DO, which means Detail Oriented, which means the same thing as AR but you don't have to use the "A" word.
        Does that make sense?
        Quik Detailer is not formulated to remove wax and in fact it and all of our mist and wipe products offer extreme lubricity to help you remove light dust, fingerprints and smudges without removing the wax coating.
        You're in good hands when you use ANY of our mist & wipe quick detailers and if you think about it you really only have three options...
        Use a quick detailer like Quik Detailer
        Wash the car
        After you wax the car, park it in your garage and don't drive it
        Quik Detailer or Ultimate Quik Detailer are VERY safe and actually great products for wiping your car down after cruising it down the road.
