NXT Tech Wax 2.0 questions
  • NXT Tech Wax 2.0 questions
    Just want to know if NXT 2.0 has a silicone in it and can be considered as a paint sealant like m21? thanks!
    Re: Next 2.0 question
    Probably does, but no big deal either way.
    And yes, Nxt 2.0 and #21 2.0 are effectively the same product, so you will be fine using either one as your wax/sealant.
      There's so much fear on the forums over silicone and it's completely unfounded. The problem with silicone is the problem of ANY substance or ingredient that would cause surface tension should it NOT be removed prior to a painter painting a car.
      Guess what? Before a car is painted the exterior is prepped for fresh paint, that means it's cleaned with a wax and grease remover and in most cases either sanded down or scuffed in some way to remove the outer layer of paint and things like car wax and to promote good adhesion by the new paint being sprayed.
      It's seriously not an issue. Whether NXT Tech Wax has silicone or if any of our waxes contain silicone I don't know unless it states it on the label.
      One thing for sure, our chemist are good, really good and when they include ANY ingredient in ANY formula it's usually for one of two reasons and in most cases both reasons..
      1. To benefit the process
      2. To benefit the user
      Ingredients are not included in a formula without a real reason.
      As to whether NXT Tech Wax is a "Paint Sealant" or a "Car Wax", that depends upon how you define those terms.
      Most people think of a car wax as a product with some kind of "Natural" waxy substance in it like Carnauba Wax, if that's your definition then NXT Tech Wax is not a car wax as all the ingredients are synthetic, that is man-made.
      The word "Wax" on the label as a descriptor is there because the majority of people that will wash and wax their car don't hang out on detailing discussion forums and dissect words and terms, instead they go to an about parts store and look for a product with the words "Car Wash" and for a product with the words "Car Wax".
      As a business, you don't make it a practice to confuse your customer.
      Make sense?
        In your subject line you wrote,
        Next 2.0 question
        That makes sense if your asking multiple questions about NXT 2.0
        Did you however mean to type NXT 2.0 Question?
        If so, we can change that for you....
          thanks mike for a clear explanation. yeah could you please change it to questions.... thanks
