Any hope for this paint?
  • Any hope for this paint?
    These pics are from my parents 87 Chrysler Fifth Avenue. To put it nicely, it was never cared for aside from the occasional drive through car wash. What exactly is this white stuff on the paint? What if anything could be done to get it looking decent? Is a respray necessary? I'm not looking to do a complete restoration, but I'd like to get it into decent shape so it doesn't look so embarassing in the driveway.
    Re: Any hope for this paint?
    That's clear coat failure. Only a repaint will fix that.
    Heatgain (Gary)
    The Irate Magistrate
    Neutral & Detached
      The paint is gone to..
      Strip and repaint will fix it
      Oxidized, Clear coat failure and likely rust in places.
        Total cc failure. Just go get a cheep paint job and then make it shine!
          Nah, it'll buff out
          Too bad you're not closer to Texas, I'd actually try
          2008 Meguiar's Batmobile Team
          2008 Meguiar's/Ford SEMA Team
          2009 Meguiar's/Ford SEMA Team
          2010 Meguiar's/Ford SEMA Team
            Nah, it'll buff out
            Really? You can fix that? Can you explain how? I thought you can't do anything with cc failure.
              I've tried buffing out a car with clearcoat failure.
              I used M84 with a wool pad to try and remove the swirls near the failure. In the end, it was useless. The paint had become so sensitive that a clean microfiber would instill scratches. In the clearcoat failure areas, the paint did not respond well to compounding. It looked a little better, but it was milky and not even close to clear.
              Chris
              Dasher Detailing Services
                Wow! The paint appears "dead" from the pics. Paint job time!! Before the paint job, get a rotary buffer and use the car as a Guinea Pig. Yeah, you can't ruin what's already ruined.
                  Step 1 sand all over with 180 grit and feather edge out all the bad spots.
                  2 sand all over with 220 grit
                  3 sand all over with 320 grit
                  4 sand all over with 400 grit wet
                  5 remove all trim and mldgs, mirrors,door handles ect.
                  6 take to MAACO for all over paint job
                  7 ask the painter to put 3 good coats of clear
                  8 bring home and wet sand with meg's 1500 grit wet
                  9 wet sand all over with megs 2000 grit wet
                  9a let paint breath for 24-48 hrs
                  10 buff all over with wool pad and megs # 105
                  11 buff all over with yellow diamond foam and meg's #86 solo
                  12 buff all over with meg's #80 speed glaze
                  13 wait 90 days hand polish megs # 7
                  14 wax 2 coats by hand meg's NXT 2.0
                  15 Sit back drink a few cold ones and admire your work.
                    Here is some pics of the worst paint issue I was to correct.
                          No hope, repaint.
                            That's exactly what I'm planning.
                              Stick a fork in it its done. Repaint time.
