Surface goo
  • Surface goo
    NOT SURE WHERE IT COMES FROM OR WHAT IT IS BUT IT COMES OFF WITH BODY SOLVENT AND ELBOW GREASE ANY IDEAS ?
    [IMG]/http://meguiarsonline.com/forums/photopost/data/500/medium/NEW_027.jpg[/IMG]
    Re: Surface goo
    ewwwwwwwwww that looks so gross......
      Re: Surface goo
      no idea but the round splats could be paintball...????
        Re: Surface goo
        Did you park under a tree? Hope after removing the substance you washed and waxed that area.
          Re: Surface goo
          Not sure the owner is elderly and runs around a lot. it does seem a lot like sap but never seen that much in 1 area before.
            Re: Surface goo
            Hum ? water would not even touch it to remove and i think paint ball is made from soap or it used to be. It did etch into the paint a little but a little 2000's wet and buff took care of it .
              Re: Surface goo
              Not sure what the goo could be but I tweaked your first post to make all the pictures show up, you made an easy mistake and that's when copying the URL address into the code box for a picture somehow you left the default
              http://
              in the box, what this does is make 2 sets of http:// in the URL address and then the photo won't show up.
              Also, it helps to hit the ENTER key a few times after your text and after each picture so the vB software won't try to display everything all run together.
              Just some helpful tips...
                Re: Surface goo
                I thought that about paintballs, but if soap dries onto paint, it may do damage????? Not sure, the round looking splats peeked my interest.
                  Re: Surface goo
                  http://
                  Thanks Mike I wasen't sure what I did. Looks much better now.
                    Re: Surface goo
                    Thanks Mike I wasn't sure what I did. Looks much better now.
                    The WYSIWYG editor in vBulletin works pretty good but if you like you can switch to "Code View" and then look at and tweak the code.
                    The Code View button is the little one to the upper right that looks like 2 letter A's
                    This one
