Updated: Rear tailight scratches need help.
  • Updated: Rear tailight scratches need help.
    Originally posted by RacerX88 View Post
    So, with a used car comes some work.... the next thing I want to tackle is this tail light damage... I didn't see it in my pre-delivery walk around so, it's on me. Is there hope? I have put some quick wax on but, I knew that wouldn't help this!
    Do I need to tape off, wet sand, then polish with #10?
    Thanks for the help.
    Based on all of the great feedback from my OP I learned about another great Megs product PlasticX which I picked up on my last trip to Advance Auto Parts.
    After washing and drying the car I started with a few applications of PlasticX by hand using a terry applicator pad. I like the progress I was making. After a few more passes with the terry applicator pad I switched to a MF towel.
    Here's the after...
    Some notes on my process:
    • Each application by hand was about 45 seconds long in the 83 degree heat.
    • I did about 5-7 applications.
    • Each application was worked in till the car was rockin'.
    • PlasticX was wiped off while still wet.
    All I can say is wow! My Wife couldn't believe the results either. I had to show her where the scratch was located.
    When applied correctly...Megs RAWKS!
    Rob A.
    '07 Kia Optima (Gold)
    Re: Updated: Rear tailight scratches need help.
    Great work. The lens looks better then new. Your right, Plast-x is another great Meguiars product.
      Very nice results! I've found that if you need something a little stronger you can use M105 by hand and follow that up with PlastX to a very nice shine, and less passes required
        Thanks for that tip about M105...yet another reason to buy some of it.
        Rob A.
          Great results, the light looks new now.
