Final Inspection as Clay Lubricant
  • Final Inspection as Clay Lubricant
    I've been reading that the preferred lubricant for claying is Last Touch (1:1). How about using Final Inspection? I got a lot of that left. If Final Inspection is okay, is there a optimal dilution ratio? What are the pros and cons of one over the other?
    At this point, one negative for me is that I gotta go out and buy Last Touch.
    Re: Final Inspection as Clay Lubricant
    The only drawback to using #34 as a clay lube is that it's a bit of a pricey way to go. IIRC, I don't believe it's made to be diluted as Last Touch can be and hence the advantage to the latter.
    Mort
      Final Inspection would be used straight.
        #34 is to be used straight. It is a great lube!!
        Kelly
        MOL- Welcome to the world of real detailer's
          Its great but as Mort said, it gets kind of expensive. Try the last touch. Diluted 1:1 you get 2 gallons for the price of one. Very cost efficient.
