No.7 & No.21 with some question please.
  • No.7 & No.21 with some question please.
    Hello everybody i'm a new members here.
    I just brought meguiars No.7 and No.21
    and i want to use it with Dual-Action machine
    but i don't know which type of pad that i should using with No.7 and No.21
    another question, which one I should use first?
    Thank you very much.
    Re: No.7 & No.21 with some question please.
    #7 is a pure polish so it should be used first. You can use a finishing pad with both #7 and #21.
      for both of them you will need a pad like the W9006 finishing pad and speeds 1-2 with about 10lbs of pressure on the had or less.
      7 is a polish so that will need to go on first one panel at a time then followed with 21
      Thoryamaha919 AKA Evan
        Thank you everybody.
          What are you working on ?
          As mentioned M07 Show Car Glaze is a pure polish and in Meguiar's terminology that means it's a non-abrasive polish. If you want to remove swirls and scratches this would not be the right product.
          As for pads, you can use a finishing pad to apply both of these but #7 is very oily and using a pad that's just a tick stiffer tends to make it easier to work a product like #7.
          So maybe get one W-8006 Polishing Pad and one W-9006 Finishing Pad or if you want the added bonus of being able to wash them in the washing machine then get one W8207 Polishing pad and on W9207 Finishing Pad.
          W8207 - Foam Polishing Pad - Yellow
          W9207 - Foam Finishing Pad - Black
            Just another tip.....DO NOT let the #7 dry (21 yes). Work it in a little and wipe it off.
            Mort (who let #7 dry in error one time and learned this the hard way)
              Great tip!
              Here's some more information on this topic...
              Which products need to dry before removing?
                Is that mean I can use No.7 with W8207 - Foam Polishing Pad - Yellow
                and using No.21 with W9207 - Foam Finishing Pad - Black
                right? I ever paste No.7 and let it dry too, It's very hard to remove it.
