I've been using cleaner wax for a while now but I think I might have been using it wrong, does cleaner wax have diminishing abrasives in it?
I always wiped it on like you would a wax then using some "passion" wiped it off.
I was reading somewhere that with color x you should use some passion to work in the abrasives then let dry and wipe of, is this the same for cleaner wax? Should I basically work it, then allow to dry and wipe off to get the most out of it? or is how I'm using it ok?
Thanks!
Thanks!
